Re: I'll bring the marshmallows
Ron Brown /
Nick,
If your Puch has DC power then by definition, it must allready have diodes to convert what comes out of the flywheel alternator which can only produce AC.
I think you are confused by the fact that you have a hot wire and a ground wire. This does not make it DC, AC is wired exactly the same way.
If you have no other way to test, put a diode in series with your headlamp, either way around and fire up the ped. If the light goes out or does not change, you have DC, if it dims significantly you have AC.
If it is DC I'll email you a buck! : )
Ron
  Battery on PuchTopic by: Nick Nick 10/06/01 09:04AM
  Re: Battery on PuchRe: InfectedBootSector InfectedBootSector 10/06/01 12:54PM
  Re: Battery on PuchRe: Nick Nick 10/06/01 01:44PM
  Re: Battery on PuchRe: InfectedBootSector InfectedBootSector 10/06/01 02:27PM
  Re: Battery on PuchRe: Nick Nick 10/06/01 02:52PM
  Re: Battery on PuchRe: InfectedBootSector InfectedBootSector 10/06/01 03:52PM
  Re: Battery on PuchRe: oldtimer oldtimer 10/06/01 05:34PM
  Re: I'll bring the marshmallowsRe: Jim C. Jim C. 10/07/01 12:22AM
  Re: I'll bring the marshmallowsRe: Nick Nick 10/07/01 05:46PM
  Re: I'll bring the marshmallowsRe: oldtimer oldtimer 10/07/01 06:30PM
  Re: I'll bring the marshmallowsRe: Nick Nick 10/07/01 11:27PM
  Re: I'll bring the marshmallowsRe: Ron Brown Ron Brown 10/08/01 11:34AM
  Re: I'll bring the marshmallowsRe: Roberto Roberto 10/08/01 02:11PM
  Re: I'll bring the marshmallowsRe: Nick Nick 10/08/01 08:26PM
  Re: I'll bring the marshmallowsRe: Nick Nick 10/08/01 08:33PM
  Re: I'll bring the marshmallowsRe: Nick Nick 10/08/01 08:15PM
  Re: I'll bring the marshmallowsRe: Ron Brown Ron Brown 10/09/01 12:48PM
  Re: There is a wayRe: oldtimer oldtimer 10/09/01 06:49PM
  Re: There is a wayRe: Nick Nick 10/09/01 09:39PM
  Re: There is a wayRe: Brandon Brandon 07/11/06 04:41PM
  Re: There is a wayRe: brystheguy brystheguy 07/11/06 04:47PM
  Re: There is a wayRe: Chris Chris 07/14/06 01:23AM
  Re: There is a wayRe: Chris Chris 07/14/06 01:25AM
  Re: There is a wayRe: Daniel Daniel 07/14/06 01:35AM
