Re: Stumped- Jawa Babetta
Did you read the post by "Chris" above?
He said in no uncertain terms that you do NOT have points... you have a CDI...
And in the pictures you posted I see what looks like a CDI ignition also.
So like I said .... if you have a big fat blue spark from a CDI (and from what I have read... you do)... then QUIT worrying about the ignition... put it back together and proceed with other tests on compression and fuel.
You are overlooking the simple stuff.
YES! IT WORKS!
well, for a while.
It runs fine, ( but not really constantly).....it kinda jerks a little bit...that method with the choke and air adjustment screw really worked.....
I dont think its getting enough gas or something...maybe an uneven flow? oh well, ill just keep tinkering with the air/gas mix screws until I get it to run better......itll start in about 2 pedal revolutions though.....and, in my test runs, I can see why you people like these things so much....anyway, just thought id let you all know....(and I didnt have to worry about points at all)
Thanks, and ill keep you updated,
Conal.
