Re: Stumped- Jawa Babetta
Chris /
First off your Jawa does not have points or a condenser it has electronic ignition. You mentioned that you had cleaned the rotor with carb cleaner and sand paper. Did you get any of the carb cleaner on the coils surounding the rotor? If so you may have stripped the varnish insulation off of them. You said that you have spark. Did you test this just by laying the plug against the cylinder ? If so that may not have been enough. Do this instead. Remover the spark lug cap (the Jawa does not use a supressor cap) then with the spark plug still installed hold the spark plug wire about 1 mm away from the spak plug terminal and crank the engine. You should see the spark between the wire and the plug terminal. That is the best way to do it because it takes into account the added resistance that the engines compression will add. The best to check for the float is to place it in very warm water and hold it under for a while. The warm water will cause the air in the float to expand and any rupture in the float will easilly be visable as the air bubbles escape from it.
Chris
  Stumped- Jawa BabettaTopic by: Conal Conal 10/06/01 01:15AM
  Re: Stumped- Jawa BabettaRe: Vespalad Vespalad 10/06/01 01:27PM
  Re: Stumped- Jawa BabettaRe: Conal Conal 10/06/01 07:29PM
  Re: Stumped- Jawa BabettaRe: Fred Fred 10/06/01 08:36PM
  Re: Stumped- Jawa BabettaRe: Conal Conal 10/07/01 05:02AM
  Re: Stumped- Jawa BabettaRe: Matt Matt 10/07/01 11:33AM
  Re: Stumped- Jawa BabettaRe: Conal Conal 10/07/01 02:44PM
  Re: Stumped- Jawa BabettaRe: Fred Fred 10/07/01 07:34PM
  Re: Stumped- Jawa BabettaRe: Conal Conal 10/07/01 08:31PM
  Re: Stumped- Jawa BabettaRe: Fred Fred 10/07/01 08:41PM
  Re: Stumped- Jawa BabettaRe: Fred Fred 10/07/01 08:37PM
  Re: Stumped- Jawa BabettaRe: Conal Conal 10/07/01 10:54PM
  Re: Stumped- Jawa BabettaRe: Fred Fred 10/07/01 11:05PM
  Re: Stumped- Jawa BabettaRe: Fred Fred 10/07/01 11:06PM
  Re: Stumped- Jawa BabettaRe: gimmyjimmy gimmyjimmy 10/07/01 11:31PM
  Re: Stumped- Jawa BabettaRe: Vespalad Vespalad 10/08/01 12:07AM
  Re: Stumped- Jawa BabettaRe: Fred Fred 10/08/01 12:37AM
  Re: Stumped- Jawa BabettaRe: Fred Fred 10/08/01 12:39AM
  Re: Stumped- Jawa BabettaRe: Conal Conal 10/08/01 01:42AM
  Re: Stumped- Jawa BabettaRe: Chris Chris 10/08/01 02:11AM
  Re: Stumped- Jawa BabettaRe: Conal Conal 10/08/01 02:44AM
  Re: Stumped- Jawa BabettaRe: Conal Conal 10/08/01 08:55PM
  Re: Stumped- Jawa BabettaRe: Conal Conal 10/08/01 08:58PM
  Re: Stumped- Jawa BabettaRe: Conal Conal 10/08/01 09:02PM
  Re: Stumped- Jawa BabettaRe: Fred Fred 10/08/01 10:00PM
  Re: Stumped- Jawa BabettaRe: Conal Conal 10/09/01 01:06AM
  Re: Stumped- Jawa BabettaRe: Conal Conal 10/08/01 09:09PM
  Re: Stumped- Jawa BabettaRe: Acosi151 Acosi151 10/09/01 08:50AM
  Re: Stumped- Jawa BabettaRe: Conal Conal 10/09/01 05:02PM
  Re: Stumped- Jawa BabettaRe: Fred Fred 10/09/01 11:20PM
  Re: Stumped- Jawa BabettaRe: Vespalad Vespalad 10/09/01 12:21PM
  Re: Stumped- Jawa BabettaRe: Conal Conal 10/10/01 12:09AM
