Re: vespa carb jetting
XBrandon EdgeX /
Sounds like it might be a vaccum leak somewhere. Spray some carb cleaner or starting fluid on the joint between the engine and the carb while the bike is running. If the engine speed changes or sounds different, you've got a vaccum leak. Try putting some teflon tape or gasket maker around the tube that the carburator slides onto. Also, make sure the airscreen is intact.
  vespa carb jettingTopic by: XBrandon EdgeX XBrandon EdgeX 10/05/01 11:48PM
  Re: vespa carb jettingRe: John John 10/06/01 12:00AM
  Re: vespa carb jettingRe: XBrandon EdgeX XBrandon EdgeX 10/06/01 12:04AM
  Re: vespa carb jettingRe: Jim C. Jim C. 10/07/01 12:24AM
  Re: vespa carb jettingRe: Chris S Chris S 10/07/01 01:43AM
  Re: vespa carb jettingRe: XBrandon EdgeX XBrandon EdgeX 10/07/01 02:29PM
  Re: vespa carb jettingRe: Vespalad Vespalad 10/07/01 11:59PM
  Re: vespa carb jettingRe: XBrandon EdgeX XBrandon EdgeX 10/08/01 12:34AM
  Re: vespa carb jettingRe: Fred Fred 10/08/01 01:03AM
  Re: vespa carb jettingRe: Chris S Chris S 10/08/01 09:40PM
  Re: vespa carb jettingRe: Vespalad Vespalad 10/08/01 10:08PM
  Re: vespa carb jettingRe: Chris S Chris S 10/09/01 11:24PM
  Re: vespa carb jettingRe: XBrandon EdgeX XBrandon EdgeX 10/08/01 10:48PM
  Re: vespa carb jettingRe: Ron Brown Ron Brown 10/09/01 01:11PM
  Re: Air BoxesRe: Jim C. Jim C. 10/09/01 12:33AM
