Re: vespa carb jetting
Vespalad /
I own 2 ciaos, a 78 and a 79. The jet on the 78 is a .43, on the 79 its a .45. I swapped them to see what kind of difference it would make. ( I should add here that I had 2 of the 3 holes plugged on the air box of the 79, It seemed like it was 4 stroking and plugging the holes fixed it in a snap.) With the .43 jet in the 79 (instead of the .45) it has better acceleration, but top speed stayed the same, and it runs like a champ without the plugged holes. Then I ran it without the air box at all, same deal, even better acceleration but no change in top speed. I replaced the airbox for the time being (to prevent any airborne particles from entering the engine), but am considering either replacing it with the 6 holed Grande air box, or just drilling some more holes in my ciao airbox to increase air flow. On tuesday my .41 and .39 jets should come in (hopefully), and I will let you know what kind of difference (if any) it makes. Brandon, does this help you at all? And where did you find a performance pipe? What brand is it? How much did it cost?
  vespa carb jettingTopic by: XBrandon EdgeX XBrandon EdgeX 10/05/01 11:48PM
  Re: vespa carb jettingRe: John John 10/06/01 12:00AM
  Re: vespa carb jettingRe: XBrandon EdgeX XBrandon EdgeX 10/06/01 12:04AM
  Re: vespa carb jettingRe: Jim C. Jim C. 10/07/01 12:24AM
  Re: vespa carb jettingRe: Chris S Chris S 10/07/01 01:43AM
  Re: vespa carb jettingRe: XBrandon EdgeX XBrandon EdgeX 10/07/01 02:29PM
  Re: vespa carb jettingRe: Vespalad Vespalad 10/07/01 11:59PM
  Re: vespa carb jettingRe: XBrandon EdgeX XBrandon EdgeX 10/08/01 12:34AM
  Re: vespa carb jettingRe: Fred Fred 10/08/01 01:03AM
  Re: vespa carb jettingRe: Chris S Chris S 10/08/01 09:40PM
  Re: vespa carb jettingRe: Vespalad Vespalad 10/08/01 10:08PM
  Re: vespa carb jettingRe: Chris S Chris S 10/09/01 11:24PM
  Re: vespa carb jettingRe: XBrandon EdgeX XBrandon EdgeX 10/08/01 10:48PM
  Re: vespa carb jettingRe: Ron Brown Ron Brown 10/09/01 01:11PM
  Re: Air BoxesRe: Jim C. Jim C. 10/09/01 12:33AM
