Ivan-I found the CDI but?
theres no blue wire coming from it, it is under the nose cone as you said, there are 6 wires coming out of it,one is white w/blue stripe 1 black,1 brown and the rest are black w/stripes is there any danger to the unit to unplug each wire at a time to see if its the one? thanks for your help Roger
Re: Ivan-I found the CDI but?
hmm well try disconnecting the blue and white wire then running it se if its better and if not put if back together and take it to a shop to have them do it
