Re: Is this a clutch problem?
Richard /
Jeff,
I've been "tolerating" this exact same problem with my 1975 Batavus HS-50. The nut that holds the clutch assembly onto the crackshaft is tight but the clutch assembly turns without the engine turning over. It seems the clutch kas a key on it that is worn off. Might yours be having a similar issue? I could get a beautiful spark when I took the plug out and tested it but the engine couldn't turn over once there was compression. I had to manually craft a locking key that would keep the clutch in place. So far it's working.
Richard
  Is this a clutch problem?Topic by: Jeff K Jeff K 10/03/01 08:26AM
  Re: Is this a clutch problem?Re: dj_dick dj_dick 10/03/01 09:13AM
  Re: Is this a clutch problem?Re: Jeff K Jeff K 10/03/01 09:20AM
  Re: Is this a clutch problem?Re: don-ohio don-ohio 10/03/01 11:04AM
  Re: Is this a clutch problem?Re: Jeff K Jeff K 10/03/01 11:14AM
  Re: Is this a clutch problem?Re: Reeperette Reeperette 10/03/01 05:39PM
  Re: Is this a clutch problem?Re: Richard Richard 10/03/01 06:15PM
  Re: Is this a clutch problem?Re: Chris Chris 10/03/01 11:23PM
