Re: Is this a clutch problem?
don-ohio /
I'm not sure how your bike is set up,but on a lot of bikes,you have a clutch lever which pushes a friction plate against the clutch hub to engage the engine when you kick it over.THEN the engine rpms do the rest.With my ANKUR though,it's a decompression lever only.It has a disengagement spring which will let you pedal the bike home if you have to.Is your disengagement possibly stuck?I just don't know Jawas.
  Is this a clutch problem?Topic by: Jeff K Jeff K 10/03/01 08:26AM
  Re: Is this a clutch problem?Re: dj_dick dj_dick 10/03/01 09:13AM
  Re: Is this a clutch problem?Re: Jeff K Jeff K 10/03/01 09:20AM
  Re: Is this a clutch problem?Re: don-ohio don-ohio 10/03/01 11:04AM
  Re: Is this a clutch problem?Re: Jeff K Jeff K 10/03/01 11:14AM
  Re: Is this a clutch problem?Re: Reeperette Reeperette 10/03/01 05:39PM
  Re: Is this a clutch problem?Re: Richard Richard 10/03/01 06:15PM
  Re: Is this a clutch problem?Re: Chris Chris 10/03/01 11:23PM
