A quick check
Miniengine /
One way to check if your rear wheel bearing is bad is to check for play before removing the wheel from the moped. Remove the drive chain and with the moped on the kick stand grab hold of the rear wheel and pull back and forth. If you can feel play in the wheel then you know where your vibration is coming from.
Brian
Lamborn's Miniature Engines
http://www.geocities.com/miniengine
  TOMOS VIBRATIONTopic by: chuck chuck 10/01/01 08:49PM
  Re: TOMOS VIBRATIONRe: Steeltoad Steeltoad 10/01/01 11:18PM
  Batavus Technical BulletinRe: Miniengine Miniengine 10/02/01 10:37AM
  A quick checkRe: Miniengine Miniengine 10/02/01 10:54AM
  Re: A quick checkRe: don-ohio don-ohio 10/02/01 11:30AM
  Good counter pointRe: Miniengine Miniengine 10/02/01 10:26PM
  Re: TOMOS VIBRATIONRe: don-ohio don-ohio 10/02/01 08:53AM
  Re: A quick checkRe: Matt Wilson Matt Wilson 10/02/01 01:42PM
  Re: TOMOS VIBRATIONRe: Reeperette Reeperette 10/02/01 06:51PM
