Batavus Technical Bulletin
Miniengine /
This was taken from the tech. bulletin for a Batavus, but I feel it holds true for any moped.
Quote:
In the past few months, we have experienced a few rear wheels with bearing problems. We feel at this time, that the bearings, cup, spindle and cones are not the problem. When servicing or preparing a new moped, make sure that the tension of the "drive" chain is not too tight.
The drive chain should have at least 3/4" to 1" slack or play in it. Be sure to rotate rear wheel a full revolution while adjusting drive chain to assure the proper adjustment of 3/4" to 1" in all positions. If the chain is too tight, this will cause unnecessary wear to the bearings.
End Quote:
I'm sure tightening the chain will temporarily fix the vibration problem, but this may be an early warning sign that your rear bearing is going bad. It's easy enough to replace a bearing, but a lot harder to find a replacement wheel with a good hub that hasn't been destroyed by a neglected bad bearing. I hope this helps.
Brian
Lamborn's Miniature Engines
http://www.geocities.com/miniengine
  TOMOS VIBRATIONTopic by: chuck chuck 10/01/01 08:49PM
  Re: TOMOS VIBRATIONRe: Steeltoad Steeltoad 10/01/01 11:18PM
  Batavus Technical BulletinRe: Miniengine Miniengine 10/02/01 10:37AM
  A quick checkRe: Miniengine Miniengine 10/02/01 10:54AM
  Re: A quick checkRe: don-ohio don-ohio 10/02/01 11:30AM
  Good counter pointRe: Miniengine Miniengine 10/02/01 10:26PM
  Re: TOMOS VIBRATIONRe: don-ohio don-ohio 10/02/01 08:53AM
  Re: A quick checkRe: Matt Wilson Matt Wilson 10/02/01 01:42PM
  Re: TOMOS VIBRATIONRe: Reeperette Reeperette 10/02/01 06:51PM
