Re: maxi 2hp
tabpat /
It depends on what is restricting it before the carb. The air filter box can be "choked down" to help in the restriction and the stock filter is also pretty restrictive. If it can't get much air into the carb, jetting higher will only slow it down and "4 stroke." Try some alternatives there.
  maxi 2hpTopic by: plp plp 09/28/01 11:32PM
  Re: maxi 2hpRe: tabpat tabpat 09/28/01 11:45PM
