Honda Melody Needs HELP
<HTML>hi
my honda melody is not working right when you dive it around for a bit it is fine but after a while you will pull the throtle back and it will cut out or not accelerate
very well
so if you could help me
THANKS</HTML>
RE: Honda Melody Needs HELP
<HTML>you have to clean your air filter and your carburateur ,
then you will have the perfect machine and throttle control </HTML>
I also have this problem, so I would like to thank you! Now I can drive without problems! THANKS!
Carol
