Moped Idle - HELP!!!!
Ryan Price /
<HTML>I am having problems trying to get a 1983 Peugeot 103 to idle. It will ONLY idle if I have the choke pulled about half way in. Any ideas?
Ryan</HTML>
RE: Moped Idle - HELP!!!!
<HTML>i do not now</HTML>
<HTML>I can't stress that a carb should be clean. I know little to nothing about most mopeds. However, when mine would not run and then would not idle, I came here. The answer from so many was to clean that carb out and make sure it is squeaky clean. It now runs better than I can ever remember. Also check the fuel filter, if any. It could be clogged enough to restrict the amount of fuel. How's that for a guess?
</HTML>
<HTML>You need to adjust the mixture. It sounds like your bike is getting to much air and not enough gas the adjustment is made by turning the screw counter clockwise. If this doesn't fix it try reseting the throtle cable. </HTML>
<HTML>You can have a vaccume leak or the idle
circuit is part clogged. Put bike on stand,
and remove air filter, get it running and
rev-up, then cover the carb. opening and let
it choke to it quits (throddle still in
rev-up position) dry off your spark plug and
put back togeather. This will suck trash out
of idle circuit....also there is a super
addative called "SEA FOAM" cleans carb and
carbon in cylendar, it works. Ryan Price wrote:-------------------------------I am having problems trying to get a 1983 Peugeot 103 to idle. It will ONLY idle if I have the choke pulled about half way in. Any ideas?Ryan</HTML>
