Re: battery?
Jim C. /
For the record, moped headlights run off the magneto (alternator) and not the battery.
They will normally get brighter as the engine RPMs increase and likewise dim when the engine idles.
In a case where the headlight dims and brightens as you ride, I would check all the electrical grounds, then all the connections in the headlight circuit. As long as the headlights gain normal brightness, even if occassionally, it indicates atleast the output to it is normal.
Jim
  battery?Topic by: pat pat 09/27/01 11:40PM
  Re: battery?Re: Jim C. Jim C. 09/28/01 12:33AM
  Re: battery?Re: Ron Brown Ron Brown 09/28/01 11:22AM
