coil differences??
my 79 motron has a bad 6v coil i think. I read plenty of voltage coming out of the engine, but only about 2v coming out of the coil
My question,,,
I borrowed a coil from my buddies (79 6v ped),, and MY coil only has ONE metal stab that accepts the input voltage from the motor. My BUDDIES coil (from a same vintage 6v ped) has TWO stabs.
Whats the difference?
I'm not sure I can use his as a 'test' on mine, is that true?
thanks in advance
Re: coil differences??
Ron Brown /
Jim,
One spade lug should be tied to ground. Check your friends ped to see which one that is then tie it to ground on your ped.
Ron
