testing an external coil
Jim /
i have a 79 motorn medalist moped,, (6v),, and suspect the coil may be bad. I cant find a cycle shop that says they can test it.
Should i get continuity between the grounding bar that is molded into the coil and the spark plug cap?
This coil has a grounding/mounting bar modled into the coil housing. All the lighting/horn grounds fasten to the ground bar.
I also get continuity between the grounding bar on the coil and the metal stab that accepts the ingition wire from the condensor.
I'm not sure,, but i expected to only read continuty between the metal stab for the ingition wire, and the spark plug cap.
Here is a link to a few pictures of what my coil looks like,,
http://www.themopedjunkyard.com/pointscond.html
any help???
  testing an external coilTopic by: Jim Jim 09/21/01 07:52PM
  Re: testing an external coilRe: Dan Dan 09/21/01 10:16PM
  Re: testing an external coilRe: Wayne Broderick Wayne Broderick 09/22/01 03:51AM
  great tip dwayneRe: Jim Jim 09/22/01 11:34AM
  Re: testing an external coilRe: Ron Brown Ron Brown 09/22/01 11:49AM
