testing an external coil
i have a 79 motorn medalist moped,, (6v),, and suspect the coil may be bad. I cant find a cycle shop that says they can test it.
Should i get continuity between the grounding bar that is molded into the coil and the spark plug cap?
This coil has a grounding/mounting bar modled into the coil housing. All the lighting/horn grounds fasten to the ground bar.
I also get continuity between the grounding bar on the coil and the metal stab that accepts the ingition wire from the condensor.
I'm not sure,, but i expected to only read continuty between the metal stab for the ingition wire, and the spark plug cap.
Here is a link to a few pictures of what my coil looks like,,
http://www.themopedjunkyard.com/pointscond.html
any help???
Re: testing an external coil
I do some work on lawn mowers .I take coils for the tractors in to a snall engine shop and they check them. Just a suggestion Dan
Wayne Broderick /
Get it all hooked up and put your tongue on it, with your free hand on the negative ground. That should let you know if it's allowing current through-- you can go from there
great tip dwayne
good tip!
Ron Brown /
Jim,
From the plug wire to ground, you should read several K-ohms, maybe 5 - 15 K-ohms. From the points connection to ground you should read between 0.5 and 1.5 ohms.
To test the coil, connect a spark plug from the plug wire to coil ground, connect an ignition condensor (any will do for this test) between the points terminal and coil ground. Connect the negative of a 6V battery to coil ground and touch the points terminal momentarily with the positive lead. This should give you a spark at the plug.
Ron
