moped isnt shifting right
<HTML>i have a 1999 tomos moped, when i am riding it, it sounds like it is reving too high before it finally shifts into second gear. Is there anything i could do to get it to shift sooner?
</HTML>
RE: moped isnt shifting right
<HTML>Tim;
This is a common problem with newer Tomos'. My 95 did the same thing. To fix this do the following:
1 ) Drain the oil from the gearbox.
2 ) Remove the right side cover.
3 ) Remove the nut that holds the clutches and clutch drum on the crank shaft being careful too remember how it all comes apart.
4 ) The clutch to be modified is the innermost one, the second one you come to.
5 ) Take a small triangular file and cut two diagonal grooves evenly spaced in the clutch material about half way into the material. Note: Don't do this to the low speed clutch.
6 ) Reassemble in reverse order of disassembly. Don't forget the oil!
let me know how you make out.
Jon</HTML>
<HTML>my 1986 honda spree doesnt accelerate correctly. It takes off slowely and takes about 5 to 10 seconds to finally gain some speed. i have allready replaced the clutch pads but it didnt help any. the acceleration is very slow and i dont know what to do.</HTML>
slow acceleration
<HTML>i have a 1986 honda spree and the acceleration is very weak. It takes me 5 to 10 seconds to finally gain speed. i have allready replaced the clutch pads and that didnt help any. What can i do?</HTML>
