my motron wont spark!!! HELP
Hi,
I am really frustrated,,
I own a 79 motorn medalist,, with a milarelli 50 cc engine. It ran GREAT up to a few weeks ago, and now i'm really bumming!
I have only had it a month or so,, and decided to replace the horn (that never worked). Without realizing it,, i replaced it with a 12v horn, and after starting it with the new horn,, my ped ran for a few minutes,, then quit, and hasn't started since.
No spark at the plug !
I have done the following with no improvement:
replaced the condensor
cleaned and adjusted the points
visually checked all the wiring, no shorts noticed
had the external coil tested,, seems to be ok
i have noticed that while turning it over,, with the light switch on,, all the lights work,, EXCEPT THE BRAKE LIGHT,,but no spark at the plug.
I am no mechanic,, but there seems to be 2 internal coils,, is one for ingition,,,and one for lighting?
Any ideas?
Re: my motron wont spark!!! HELP
Jamie Leonard /
Well I'm by no means the guru... but for many mopeds the brake light is effectively in the same circuit as the ignition (meaning if the brake light is out, the moped will not start)
Have you checked the brake light bulb and wiring?
checking now,,,,,will get back to you,,,
any good tips on where i can get a manual and / or schematic?
Jamie Leonard /
Keeping an eye on ebay is always a good idea (since manuals do crop up regularly for a variety of mopeds) but aside from that, some of the online retailers mentioned in the forums (like mopedwarehouse.com, or personally I use torontomopeds.com but they are a bit pricey in terms of ordering from the states :)
Decent enough pricing for me though and I like the service.
I have finished a complete test of the wiring harness, and all it a-ok.
All lights work, inlcluding the all imporntant brake light!
I verified all switches are operating as expected (on/off, brake light and light/horn)
STILL no spark!
Trying to get a buddys coil to try on my ped to see if that works,,,
other than that,,, what else is left?
thanks!
