Tomos ignition coil question...
Recently we replaced an iginition coil on a 12v 92 TomosTTLX with an old ignition coil from an old bike...it seems to work but we do not know what the voltage is on the old ignition coil.
How would I be able to check what the coil voltage is on the old coil and would a 12v system run with a 6v coil?
If it is the wrong coil..what would the symptoms be?
Lois
Re: Tomos ignition coil question...
Reeperette /
>>If it is the wrong coil..what would the symptoms be?<<
That it doesn't work.
I doubt a 6V coil would work either, but if you have spark, I do believe you are close enough, parts-wise.
-Ree
