sound barrier
my 1982 nc50 express regularly reaches 38 mph (downhill, full throttle and a decent tail wind) but still resists starting without great difficulty on chilly mornings, any suggestions?
Re: sound barrier
the choke doesn't help it get started when cold?
Re: sound barrier
SteelToad /
This may sound crazy, but... try removing the gascap, replacing the gascap, and
then starting it. I had an old car that would NOT start on cold mornings unless I
did that. I got the suggestion from an old timer who I thought was nuts till it worked
My fuel system was messed up to start with, when It got really cold, the tank
would create a vacum and suck the gas back up the line.
Re: sound barrier
thanks toad, i'll try it tomorrow
Re: sound barrier
Wayne Broderick /
My 1978 honda express did this too. On mine, there was a switch on the gas cap, to make a vacuume, if you forgot to turn that switch, the suction would build and the moped would die.... untill you opened the switch or took off the cap
