Re: Up-jetting A35 Tomos Carb
Don Pflueger /
your stock jet is #53. you need to order a #54, #55, and #56 from ikes bikes, www.ikesbikes.com. they cost $3 each. you remove your carb, remove the black bowl on the bottom of the carb, replace the jet in the center of the carb body with one of the 3 you ordered, and then do plug chops to see where your at. #55 should be just about right for your bike.
