jawa 140
trying to get spark, no luck. have noticed 2 wires with terminals on back fender rack and have idea what they connect to.can anyone help this dummy?
Re: jawa 140
sorry , should read "NO idea"
Re: jawa 140
Reeperette /
I believe I can.
From your description I would say those wires are supposed to go to a tail light...which apparently is not there.
And that leads in to your other problem - as a safety measure, a lot of mopeds will not fire the spark plug if the tail light is not fully functional.
I would need more information to go any further on this one.
And no...you are not a "dummy"...simply inexperienced with your new machine, and that, friend...we shall remedy in short order.
Try Freds Guide in the Resources links - if you have not already, it's hands-down the best document to keep close to hand..print it out and keep a copy with you.
-Ree
Re: jawa 140
hve you checked the points...under the flywheel. better get a manuel.Reeperette wrote:
> I believe I can.
> order.
> -Ree
