Re: Carburator-to-airbox hose fun (Spree)
Gros Pingouin /
> Have you had the airbox off lately?
Actually, I have never taken it off. Lazy, huh? =)
> One of the mounting tabs may be on the wrong sides of the
> bosses it mounts to
I will check that just in case the previous owner did not mount it right =)
> However.... Spree airboxes do tend to 'sag' away from the carb.
> All the mounting screws need to be in place.
Will check that
> If that still doesn't work
> Use some wire or duct tape to 'pull' it back into place.
The handyman's secret weapon? ;)
> And are you using the 'hoseclamp" that holds the boot onto
> the carb ?
> Got to have that.
Well, the clamp that was trying to hold the boot to the carb did not seem to be able to clamp tight enough to hold the boot in place. I guess I will have to find something similar but that works ;)
  Carburator-to-airbox hose fun (Spree)Topic by: Gros Pingouin Gros Pingouin 09/15/01 11:26PM
  Re: Carburator-to-airbox hose fun (Spree)Re: Fred Fred 09/16/01 05:34PM
  Re: Carburator-to-airbox hose fun (Spree)Re: Gros Pingouin Gros Pingouin 09/18/01 12:48AM
