biturbo baffle??????
Hi, rumor has it that removing baffle from biturbo exhaust will help a little with more speed. is it true?? any answers would be gratful.
Re: biturbo baffle??????
XBrandon EdgeX /
probably not a whole lot, it will just make it louder. usually,the performance of an expansion pipe comes from the back-pressure it provides, and the baffle is designed in conjunction with the expansion chamber to produce the most effective power boost. you can try it though
Remove it. Most baffles don't do shit anyway except quite the noise, We're guys. Noise is gooooood.
Ataristyle /
I have remove all of it completely from my BiTurbo. You might want to leave a little bit in there where the gold can part of the muffler meets up with the crome chamber. This will probably prevent the oil from spitting out around the 3 rivets. You will not gain any speed at all from doing this but is much louder. It is by no means loud enough for a ticket. I couldn't even hear my muffler when riding along a '60 Cushman Eagle with a straight pipe. That cushman was LOUD!
When you remove it, clean out all those little holes... will need to drill out pop rivets to do so. I bought replacement packing from HEETERS for $6.95, its preformed, mine was oil soaked and holes clogged... Doug D.
