Just do NOT make the mistake of removing the same number of chain links as teeth. I just doesn't work that way. I went from 46 to 40, then 40 to 36. No way have I removed ten links.
If you are careful you can remove chain links in a bench vise with a hammer and punch.....and a ton of rags. Don't forget to lube the chain again after re-assembly!
Nick
