Re: Sherlock Holmes and the adventure of the large
James Corbally /
Wayne Broderick wrote:
> Do you think the "flat" spot could just be the slide between
> gears?
> For Example, on an uphill, before I added the Bi-turbo
> exhaust my Tomos had a "flat spot" around 13-15 mph. when I
> increased throttle, it made noise, but no power. after I
> added the bi-turbo, it still hits the 'flat' but at 17-20
> instead.
> That, at least on my bike, is normal. Cant get enough speed
> for to shift gears, but is kind of fast for first.
> My bike would shift fine on a slight downhill, smooth on
> level, and a little slow uphill. Like I said, it's normal.
It's an automatic, so it has variable transmission.
It does go up steep hills slowly, but I think that's more a case of belt slip.
Regards,
James...
