<HTML>I have had good luck on larger Hondas by polishing both the needle & seat areas with a good metal polish like Mothers or Blue Magic. Use a Q-tip to polish the seat to a high shine & carefully polish the needle to break any glaze on the soft tip of the needle. Be sure to use a second Q-tip to remove any residue - you can tell when it stays clean. Good luck!</HTML>
