I think its over heating
I recently put on a uni foam filter, but just today i noticed it giving much more heat off, I can feel the heat thru my shoes on the floorboard thing, and when I was checking the color on the spark plug which was a light tan/brownish, I could feel the heat from the clinder from a foot away. I put the filter in a couple of days ago and just today its doing this.
-Nick
Re: I think its over heating
Might be too much air Nick! Restrict it some and see if it helps.You don't want a blow-torch melting your piston ,man.
You are running way lean now like Don says. You'll have to put the original filter on it or jet up to richen the mixture...
Not so fast
It may have been 'way too rich' before
If his spark plug isn't going white
it is not too lean
The spark plug color is what you go by... not somebodies perception that "it feels hot"
