gas line
i need a new gas line anyone have one
Re: gas line
fuel line? any hardware store should have some. we just use clear tubing. it's very very very cheap.
Re: gas line
I assume you are talking about 1/4 inch diameter tubing. Any auto store. Cannot recommend clear poly tube. It hardens from gasoline. Use the rubber type. It can be removed and put back easily.
Re: gas line
Hi,Old-timer! I would use either type,but I like the see-thru quality of the clear tubing enough to put up with the hardening factor.Nothing like seein' that fuel go down the line when you're in doubt! (:)
