Suzuki FA 50
I bought a 1983 Fa 50 and i was woundering what kinda a fuse that goes from the battery to make the lights work better when it's idling. i have a 32v fuse in there now and it doesn't work when the engine is off.
and another this is there a govner in there or a restrictor in it. Mine cuts out of me at really bad times.
thanks in advance
Re: Suzuki FA 50
Read the post above to find a troubleshooting guide to get your engine to run.
Also... The fuse doesn't change the brightness of the lights.
And I don't think you should have a "32V" fuse in there.
I believe it should be a 5 Amp to protect your wiring and components.
If the lights don't work without the engine running, and are dim at idle, then the battery is probably dead.
