Re: Variator
Jim C. /
On the crankshaft end it should fit. The crankshafts are all the same. Be sure you have the spacer that goes behind the front pulley from the Magnum.
Compare the shafts at the rear wheel of a Magnum and TFR. If they are identical, you will have a Poor Man's Magnum in no time. Use the Magnum's drive belt also
Jim
  VariatorTopic by: Randall Perkins Randall Perkins 09/02/01 01:28PM
  Re: VariatorRe: Jim C. Jim C. 09/02/01 10:50PM
  Re: VariatorRe: Chris Chris 09/02/01 11:27PM
