Re: The Efficiency Challenge !
Ron Brown /
Your Gawdiness,
I think you may have a problem here. Most motorcycles are tuned for best eficiency at typical speed/rpm combinations. Something like 55-75 mph.
Even if you left the bike in a lower gear to gain revs and potentially get into the valve timing/intake/exhaust optimum range, you would be doing so with a much smaller throttle opening than in high gear at highway speeds.
I read a post on some site a while ago about some experimentation done in Sweden, I think, where they compared gradually accellerating up to speed vs. giving it some stick. The results showed that the faster you reached cruising speed, the less gas you used. The conclusion was that the carburetion was better at cruising speeds.
I don't know if they tested fuel injection, I imagine this would be somewhat better. Meanwhile, on the strength of this survey, get out there and peg it....er officer??
In case it helps, I will try for accurate mpg measurements on the trip to the barbeque. I am hoping to have two Motobecanes and a Batavus, all of which seem to equate "odes" to miles, not kilometers. I will begin the trip with full tanks and refill them when I get back and see what happened. Last year my best estimate was about 90 mpg for the Mb's I think. I posted the info on the site at the time but I did not have real accurate numbers. Something to do with a leaky fuel line and a guy with some gas in a non-calibrated pickle jar. : )
Your obediant subject.
  Mopeds vs motorcyclesTopic by: zxrider zxrider 08/24/01 11:00PM
  Re: Mopeds vs motorcyclesRe: Jessie S. Band Jessie S. Band 08/24/01 11:35PM
  Re: Mopeds vs motorcyclesRe: XBrandon EdgeX XBrandon EdgeX 08/25/01 12:04AM
  Re: Mopeds vs motorcyclesRe: Rick Rick 08/25/01 01:16AM
  A bit overstatedRe: Fred Fred 08/25/01 01:17AM
  Re: A bit overstatedRe: Jamie Leonard Jamie Leonard 08/25/01 03:08PM
  The Efficiency Challenge !Re: The Moped Gawd The Moped Gawd 08/26/01 07:28PM
  Re: The Efficiency Challenge !Re: Wayne Broderick Wayne Broderick 08/26/01 07:42PM
  Re: The Efficiency Challenge !Re: Wayne Broderick Wayne Broderick 08/26/01 07:55PM
  Re: The Efficiency Challenge !Re: Jamie Leonard Jamie Leonard 08/26/01 09:21PM
  Head to head is the only accurate way.Re: Fred Fred 08/26/01 11:17PM
  Re: Head to head is the only accurate way.Re: Jamie Leonard Jamie Leonard 08/27/01 01:20AM
  Head to head is the only accurate way.Re: Fred Fred 08/27/01 03:43PM
  Re: Head to head is the only accurate way.Re: jamie leonard jamie leonard 08/27/01 03:59PM
  Re: The Efficiency Challenge !Re: Ron Brown Ron Brown 08/27/01 01:36PM
  Re: The Efficiency Challenge !Re: jamie leonard jamie leonard 08/27/01 01:45PM
  Re: The Efficiency Challenge !Re: Fred Fred 08/27/01 03:20PM
  Re: The Efficiency Challenge !Re: Ron Brown Ron Brown 08/27/01 06:07PM
  Re: The Efficiency Challenge !Re: gimmyjimmy gimmyjimmy 08/27/01 10:33PM
  Re: The Efficiency Challenge !Re: Ron Brown Ron Brown 08/27/01 01:51PM
  Re: Mopeds vs motorcyclesRe: Jimmy Jimmy 09/20/01 11:03PM
  Re: Mopeds vs motorcyclesRe: TIP TIP 08/25/01 08:30AM
  Re: Mopeds vs motorcyclesRe: Peggy Peggy 08/25/01 11:25AM
  Re: Mopeds vs motorcyclesRe: Jamie Leonard Jamie Leonard 08/25/01 03:12PM
  Re: Mopeds vs motorcyclesRe: Ken Ken 08/25/01 09:39PM
  Poor man's Hot-RoddingRe: Miniengine Miniengine 08/25/01 11:51PM
  Re: Mopeds vs motorcyclesRe: Ron Brown Ron Brown 08/26/01 11:08AM
  Thanks Everyone!Re: zxrider zxrider 08/27/01 07:13PM
  Re: Thanks Everyone!Re: Ron Brown Ron Brown 08/28/01 12:12PM
  Re: Thanks Everyone!Re: Richard King Richard King 08/31/01 01:14AM
