Puch Maxi--Lights Don't Work!
You know the electric cables that attach next to your breaks. Well one of mine is missing the little spring pin, ground thingy. If one side isn't connected, should some of the lights work, or do you need both connected to make the lights work? I am not very good at the electrical part, so help would be appreciated!
Re: Puch Maxi--Lights Don't Work!
which lights are not working? and conversely, which are?
I know what I am talking about now. The brake switch was broken, and I was wondering if that could make the lights not work? Do the brake switches effect the all around lights at all, excluding, of course, the break light?
In order to help you, you have to answer the questions directly. Which lights work and which lights do not work?
