TOMOS Guru's needed
Hi all,
i have this 87 G Bullet very slow compared to my Puch.Never really worked on Tomos.Just some ????. It's starts right up. Out of the hole its alittle slow,when it goes to 2nd gear doesn't have make ether ,at top end it does some bogging.all in all top speed is about 22mph.Disappointing,
here is what i am situp at .
points - .016 sprocket frt.26 rear 22
plug - NGK B5hs carb reBuilt #57 jet
Compression- 100-105 decarbonized
I'm not puttin a new bi. exhaust on tell i get more out of it. Thats guys for any input. thanks Ree Dan
Re: TOMOS Guru's needed
try geting a smaller jet. The stock tomos jets for the Delorta Sha carbs are #52. A #57 would be the cause of a overly rich mixture, resulting in bogging and bad top speed. Try adjusting the compression also. Good Luck.
Drop your exhaust and I bet the engne speed at idle really increases,,,plugged exhaust will give lots of problems...dougD
Reeperette /
>> points - .016
Crack em - .0180 to .0200 (dependin on which works for ya)
That's a mild advance for better topend.
>>sprocket frt.26 rear 22'
Stock, no prob - I'd go 27 front with a stock rear.
>>plug - NGK B5hs
Chuck it, replace with Bosch W8AC
>>carb reBuilt
Upgrade from the Stock DelLorto (12mm?) to like, 15mm Amal.
>>#57 jet
Yowza!, too rich...51#-#53 stock...but save that #57 for when the BiTurbo goes on !
Flawless...don't mess with it, milling the head won't get you no more.
>>decarbonized
Didja check the port from the cylinder ? that tends to clog up too.
>>all in all
Mostly your mix is too rich, is the problem, but the resta that should help too.
Enjoy.
-Ree
