Peugeot carb !
Why Peugeot Carburator always bloked !?
What is the best product to clean a carburator ????
Re: Peugeot carb !
carberator and choke cleaner
Re: Peugeot carb !
Check your gas tank, is it rusty on the inside? take your carb apart and take off all the plastic or rubber pieces and let it soak in gasoline or carb cleaner overnight. if you have 1 use a air compressor to blast out all the holes and jets after it soaks.
Re: Peugeot carb !
Ron Brown /
Al,
Do what Matt said then install a fuel filter.
Ron
Re: Peugeot carb !
The gas tank is like new , no rust !!!!
Re: Peugeot carb !
Ron Brown /
Al,
If your gas tank is like new and has no dirt in it, I guess you will never get dirt in the carb. Seems to me you do not have a problem.
Ron
