Re: CHAMBER out of stock PUCH pipe,see pic.
Matt Scout The Scouting Dcon /
Man, I'm tempted to try this out on my pipe! It even looks cooler than the stock setup!
I have one of these, "Rag"pipes. Works great on a mild ported,cylinder.And the price can't be beat.Chances are, you already have it.
ha ha,, you have the one in the pic,,, it was put on the black ped.
I had to upgrade the Mrs. black one a lil' bit. High torque top end, 15mm Amal, Bi turbo. You know me, I can't leave em' stock. The Mrs. got my long seat, and I got the long face : (
wouldn't the pipe preform better if the header was cut where it meets the inside of the first cone? It would create more of a funnel and let mor gas mix enter back into the header right? The only reason the stock pipe has that long header inside the cone is to hold the baffle in. Could you shorten the header slightly for a higher powerband?
Eric
🇮🇹💦 Of the Loin /
tell me about the magnum pipe secrets!
ive got a black magnum pipe that needs modifying
bump for coolness
Indeed...Rich's shorty pipes are awesome!
Ϫ‡☄ಬ∞ ƀƖḬƝƊ ƤǂƿƎ ∞ಬ☄‡Ϫ - Hoke from Black Pipes Moped Gang /
is this in the wiki? it should be...
I still need to learn some of those old school tricks from you Rich. Looking awesome.
dear rich, rigged up a afterburner.. a moped is way cooler when shooting 5 foot flames!!
huh, I may have to try this. I don't really like loud, but I do have a lot of stock pipes right now.
Aaron, I had one of these on a 2 speed a few years ago. It was reallly loud, but it increased the top end about 3mph. It was a silly pipe...kinda cute though.
BUMP.
im tryna build this and use the remaining length of pipe that was cut as a baffle. any ideas?
Old School Brent /
I still like your other stock pipe/chamber mod, Rich. The one in your profile, where the 2 stock pipes are cut and welded together! And then finish it off with a Briggs & Straten type tubular sliencer.
bump.
I was gonna bump this 2 days ago and didn't.... thinking about doing this with one of my old stock pipes for the hells of it.
Smart like a fox Wayne told me about something like this only his way is better ! ~
it works! i did this back in 2009
i also chopped header all the way, welded, and made a silencer out of chiken wire/ fiber glass and a 2 1/4 pipe, welded. sucks after welding a piece of are-sol can made it into my main bearing on the crankshaft and kept soft siezing it. still got the crank too.
Gromosaurus Rex - Brad Pitt /
Mike Honcho of the northern michigan pednecks did this on a murray and got at least 5+mph
Rich Battag Wrote:
> WOW! an A? Thanks, I wish, I could take credit for
> the design,but it was designed by someone else and
> many others followed this pipe design.It
> WORKS,Anyway, there's a few different mods for
> cutting header and the size of exit hole at end.
> on this one I went approx.10" from header
> connector point drilled 4 holes 3/8"and went w/ a
> 3/8" exit hole at tail, also, got rid of hose
> clamp(15yr old thing) went w/ screws at top and
> bottom to hold can in place. see pic
Is the end of the header pipe caped off?
bumb for cool shit
Bump for all those stock pipes on 55 mph rippers
Probably Fred /
Not a 55 mile an hour ripper but just adding a metal mesh filter and putting one 5/16 inch hole on the inside and 1/4 in hole inside of the cap of a stock magnum ll pipe makes for a bike that feels like it’s been Kitted :
Oh ya it had new pucks and flipped 2nd gear clutch too
THIS IS MY FAVORITE THREAD
I gotta make this pipe.
Charles Cole (OFMC) /
Seems to me, there was a thread on here several years ago, where 2 stock pipes were cut so the front part was on normal and the front 1/2 of the other was turned around & welded back on to the other front, so it looked like a skinnier version of an expansion chamber. You could side bleed it or put on a normal silencer. They said it made a huge difference. I've thought about trying it. Theoretically it should work well, but not be as short as the one in this thread.
Probably Fred /
A bat style magnum pipe is nothing like a junk Maxi pipe!
it’s like apples to oranges!
You could take your magnum header and cut it off right at the junction, put one extra 5/16 hole on the inside of a magnum pipe and one extra holewhere the end cap connects and basically you got an expansion chamber that has a good power band up to 9000 RPM,
A maxi has that goofy baffle system which you do you need to have some back pressure, but otherwise it’s junk, it’s just to make your bike go slow to keep it a 20, 25, or 30 mph model but if you de restricted you may go a little faster the top end but lose all low-end power,
I would rather get a cheap pipe like a Biturbo or bullet, circuit or anything other then use a stock Maxi Pipe
The only thing a maxi pipe is good for is a buck or two you get for it at a scrap yard !
> at a scrap yard !
Ken did somone hack your account? Thought you were an Estoril dude.
