PUCH problems
Sticky Fingers /
Having a problem with a 1974 maxi puch moped! everythime i try to start it, it wont! all it does is make this loud noise! any help is apprechiated!
Re: PUCH problems
See Freds post at the front door of the Moped Army. Just out of curiosity, what exactly is this loud noise and where is it coming from?
Re: PUCH problems
Sticky Fingers /
it seems to eb comming from the motor, and sounds almost like a grinding noise, bit i dont think anything is grinding!
Re: PUCH problems
Take the flywheel cover off and the sparkplug out. Spin the engine over by hand with the starter lever pulled in and listen, grinding noises are usually accompanied with metal shavings, so look for them. You might want to drain the gearbox into a can, put some of the oil that came out between your fingers and rub, if it's got a lot of metal in it you'll feel it. Also smell it, it shouldn't smell burnt.
