carberator
I have been fixing my moped and the biggest problem is the carberator but I am not going to ask about fixing it. when you take the throttle cable of the carb there is a little pin with a stoper on it. it has other slots to put the stoper if I move it down or up does that make it go faster??
Re: carberator
Yes, it does. It's the main jet needle, moving the circlip up causes the needle to set lower in the slide putting more of the needle into the hole of the main jet letting less fuel in, that is, it gives you a leaner mixture and your engine will run cleaner, that is, not burble. You'll have to experiment to find which slot makes the bike run best over the full range of your throttle. It's better to start with a lower slot and work up ( leaner ), you'll just foul plugs. Too lean and you'll burn a hole in your piston.
