How do get rid of blue smoke from this machine.
Install an electric motor instead of a two-stroke one. I love the smell of two stroke in the morning.
Pre mix proper 2 stroke oil at a 3 oz to one US gallon ratio (43 to 1)... It won't smoke too much then... unless your
float level is too high,
or you float needle and seat are leaking,
or your petcock is leaking down some overnite
Smoke on a 2 stroke has nothing to do with the engine being worn out... like a 4 stroke engine in a car
Just check recently, theres some fluid coming out in the air intake system. Proper mixture of gas and oil is used.
You don't, what I would worry about is if it quit smoking. The blue smoke is the waste oil, no smoke, no oil, no lubrication.
As long as it's running well, don't worry about it. Two strokes will normally slobber from both ends, it's the nature of the beast.
