I'm working on moped with a Tomos A3 motor, and would like to know how to disable it. I had a block-off kit on an ATV I used to have, and you had to take a gear out of the motor for it? What do I need to do for this one? Thanks.
Hmm.. technically couldn't you just leave the oil injection tank empty and mix the oil right into the gas? (unless theres some reason why this is a bad idea, not sure offhand)
I got to thinking...I'll just put extra mixed gas into the injector tank...that shouldn't be a problem.Jamie Leonard wrote:
If you do that, reduce yer jet size by 1.
-Ree
Hey Ree, does that take a DT4-0712 Pump Extractor?
