<HTML>
I own a Honda Wallaroo but it is only going 35-40 km/h
please help me!
</HTML>
<HTML>
please help me!
</HTML>
<HTML>You can take the muffler off that'll speed it up some and make it extreamly loud.
Take the governor off then it'll fly
</HTML>
<HTML>how do you take the governor off?
how does taking themuffler off make it faster?</HTML>
<HTML>Remove teh mufler and open it up. Take the baffles out and refit teh exhaust.
Also, remove the restricting screw off teh throttle cabble and tighten the cable.
This should make your ped go between 50 or 60 mph
</HTML>
<HTML>for more top speed youmust buy a another chain link and get a bigger front sprocket on the side the engine turns the sprocket. The more power or torque for going up hills you want a smaller front sprocket and to revove a link if necessary. I fyou want a little more power take a drill and drill out the rivet for the exhaust bafflen the will make it a little bit lowder and it will. TO FIND THIS YOU MUST TAKE OFF YOUR FRONT COVER AND FIND IT LOOK OF THE BACK OR THE SIDE OF THE SPEED OMITER AND THERE IS A CABLE THIS CABLE USUALLY LEADS TO A WHEEL AND IF YOU UNSCREW THE CABLE FROM THE MOUNTING THERE IS A SMALL WIRE INSIDE TAKE THIS OUT AND THE TACHOMETER(MILEAGE) WONT WORK. tHERE IS A DOWN SIDE AGAIN THE SPEED OMITER DOESN`T WORK. YOU CAN EASILY INSTALL IT BACK IN WHEN TRYING TO SELL IT. HERE IS A VERY SPECIAL THING i DID WITH MY MOPED i CAN TURN MY FRONT WHEEL BACKWARDS AND THE MILEAGE WITH TURN BACK TO ZERO SLOWLY. THE ONLY DOWNSIDE IS THAT YOU MUST GO THAT MANY MILES THAT ARE ON BACKWARDS. I TOOK my fan apart and put a small tire on it rubbed it against it for a while I put a sand bag to hold it there. It might not be the front wheel but mine was. I have a 1998 kasea 50b moped. It is the fastest in our town and alot of people have mopeds. I jacked the rear shock up with a shackle kit and put a bigger rear tire on the rear rim this has given my moped more ground clearance and it has let the moped stay in first gear longer. you can not do this to yours but you can get a little bigger tire or pump the tire up a bit and then the tire has to make less revolutions. there are many engine things that can be done but if your not mechanically inclined these will help the most. hope this helped.
Sincerely,
a friend who wants to help </HTML>
Hej Signar Dam
P
oh come on you people don't know shit about it.. you can get an leo handmade.. a 70cc cilinder and a 21mm carburator but it won't do anything unless you place a faster cdi.. the cdi takes care of the sparks.. how many it can do in a second.. the normal cdi gives just enough sparks to get to 40 km/h.. if you put in a faster cdi it can give almost like unlimited sparks and you can get your wallaroo up to 135 km/h (mine does almost 100)
