83 honda express-cant find where gas line goes!
<HTML>i have put the gas line into the carb went to fill it with gas and it all leaked out of a tube in the bottom. i have two tubes un-connected now and one i think is a vent. i cant find where the one that leaked the gas goes. help!!!!!!!!!!!!!!!!!!!!!!!!!!!!</HTML>
RE: 83 honda express-cant find where gas line goes
<HTML>that happened with my motobecane, i took the carb off to clean it and when i put it back on i could not get it to stop leaking ( through the jet?). it turned out that i just neaded to tighten things down a lot more thatn I thought was reasonable. but now it works. </HTML>
Jake Ellis /
<HTML>Hey the line that leaked may be the float bowl over fill /drain. If so it attaches under the float bowl. Then try and tighten the bowl drain screw that is right next to the drain tube. If it doesn't work e-mail me.</HTML>
