Re: Sounds like marbles
Brian /
You'll have to pull it apart to find out, do a top end job first. If you can find nothing wrong, then it's in the lower end. Check your countershaft sprocket and make sure it's installed tight and check the guts of your exhaust to make sure they aren't loose.
  Sounds like marblesTopic by: oldtimer oldtimer 08/05/01 07:26PM
  Re: Sounds like marblesRe: larry larry 08/05/01 10:49PM
  Re: Sounds like marblesRe: Doug D Doug D 08/06/01 01:34AM
  Re: Sounds like marblesRe: Brian Brian 08/06/01 11:52AM
  All 2 strokes sound like "marbles in a can&quRe: Fred Fred 08/06/01 01:53PM
  Re: Sounds like marblesRe: don-ohio don-ohio 08/06/01 03:15PM
