Re: Flat Tire! (Kinetic TFR story and question)
Ron Brown /
Michal,
If you know where the the puncture is, you can lever that piece of the tire off the rim, pull the bad part of the tube out and patch it without removing the wheel.
If you have not done this before, have someone help you who is familiar witth bicycle tire repair.
If you do remove the wheel, check alignment and drive chain tension when you re-assemble it.
Ron
