a large gas puddle is suddenly present after parking my ciao over night. the tap on the tank is o.k. and turned off. could the float be sticking or have a hole in it. the muffler gets full of fuel. what should i look for to fix this. thanks bruce
gas leaking out ciao muffler
Re: gas leaking out ciao muffler
The tap on the tank(petcock)is bad,AND the float or needle valve is not working right,unless your tank leaks.
Bruce,
If your gas tap worked and was off, the only thing you have left is a gas tank leak. You need to pull the gas line with the tap off and see if it is leaking.
Ron
