PA50II question...
the casey /
is it possible to have a biturbo welded or otherwise attatched to my PA50II? i dont like the way it looks without a pipe... any tips?
thanks
the casey
Re: PA50II question...
yes it is... but I think it is a little bit tricky to connect a proper dia head pipe to the existing flange/collar.
A local welding shop should be able to do it for $30 or 40 maybe ??
the casey /
will it enhance performance at all?
yes... I made my own... and I prob gained 3 or 4 mph from it
(but that was on a PA50I)
Chris Robertson here had a PA50II that went 29 or 30 stock (I think) and he did the variator ramp mod and gained 4 or 5 mph (I believe)
Hey,Fred,speaking of Chris.Where'd he go? I haven't heard from him for a long time.Anybody know? Chris?You listening?
the casey /
what is the "variator ramp mod"?
thanks...
so having a biturbo welded on should increase performance?
Yes... I would think the Biturbo would gain you maybe 3mph or so.
And the 'variator ramp mod' is enlarging (with a file) the 3 grooves the outer clutch plate has in them to allow more movement of the outer clutch sheave face (it squeezes the belt tighter...raising the gear ratio.. and top speed).
Do a search for that word... CR had posted a 'pdf zip file' with 4 or 5 photo's of the mod.
Since I don't know that much about pyooters... I didn't/couldn't open it and look.
But you might know how to.
yeah dude wanna fuck, finally i got my ouch runnin can i borrow $235+tax
PM , YOUR FRIEND MATT
