Re: chain tightening-
don-ohio /
Absolutely,Rob,the back wheel should move freely with no feeling of a tight spot,then a loose spot when turning it.A too tight chain will kill your power,and it's best to be a LITTLE loose than too tight.You have to check the tension of the chain while you've got it weighed down with the normal load oof the stand `cause they usually tighten up when you get on them.Also watch that you don't misalign the rear wheel as you adjust it.BYE!
  chain tightening-Topic by: Rob Gibbons Rob Gibbons 07/30/01 11:26PM
  Re: chain tightening-Re: don-ohio don-ohio 07/31/01 12:48AM
  Re: chain tightening-Re: Sean Sean 07/31/01 12:48AM
  Re: chain tightening-Re: Ron Brown Ron Brown 07/31/01 11:58AM
