Re: Any suggestions on High-Performancing?
zxrider /
I am not sure about the U.S., but when I was a teenager living in Italy, there were all kinds of parts you could get to hot rod a 'ped. I remember exactly how it felt to be a speed-addicted teenager!
The number 1 most noticeable improvement was to buy a larger carbeurator. Your bike probably comes with a dinky little 12mm. You need at least a 14, preferably a 16. (we used to put carbs as large as 19mm on ours!)
Number 2- and post preferably in conjunction with the carb, would be a high performance exhaust pipe.
These 2 modifications alone would make a huge difference!
Also, we used to buy reed-valve kits for the intake systems, and if you had a lot of money to spend, a big-bore kit.
