Re: jetting a puch newport?
leo /
hey man
when you sanded the points down i bet you changed the timing somewhat...
go back and check your TDC and timing too.....somebody else said to
make sure you did a gentle break-in after all this engine work....not a bad idea.
man, its a minor problem.....at least it runningFred wrote:
> just a dumb question
> did you make sure to get the ring end gaps installed at the
> retaining pins in the piston grooves?
> And if you put in a new top end... did you take a few miles
> to break in your new piston and rings?
> I would do a compression check to see if everything is still
> alright on that new top end.
  jetting a puch newport?Topic by: larry larry 07/29/01 01:39PM
  Re: jetting a puch newport?Re: don-ohio don-ohio 07/29/01 02:05PM
  Re: jetting a puch newport?Re: Rob Gibbons Rob Gibbons 07/29/01 02:10PM
  Re: jetting a puch newport?Re: don-ohio don-ohio 07/29/01 02:22PM
  Re: jetting a puch newport?Re: larry larry 07/29/01 05:14PM
  Re: jetting a puch newport?Re: don-ohio don-ohio 07/29/01 05:38PM
  Re: jetting a puch newport?Re: larry larry 07/29/01 05:59PM
  Re: jetting a puch newport?Re: don-ohio don-ohio 07/29/01 06:09PM
  Re: jetting a puch newport?Re: larry larry 07/30/01 04:49PM
  Re: jetting a puch newport?Re: XBrandon EdgeX XBrandon EdgeX 07/29/01 06:25PM
  Re: jetting a puch newport?Re: Fred Fred 07/30/01 01:13AM
  Re: jetting a puch newport?Re: leo leo 07/30/01 02:39PM
  Re: jetting a puch newport?Re: larry larry 07/30/01 05:01PM
